Ducati Multistrada MTS 1200 Frame Slider Kit by Motovation Accessories
These frame sliders protect the mid section of your Ducati Multistrada frame water pump and crank case during a slide. They are longer than the ones for the Streetfighter and the profile of the slider is different. This kit is specially made for the Ducati Multistrada.
These frame sliders have been designed with a 12 mm stainless steel through-the-engine rod that is threaded at both ends. Stainless steel was chosen because it provides a better bearing surface due to the material's natural slickness that reduces engine to rod friction during engine running.
These sliders have the same quality and attention to detail that you have seen in all of our previous products. Please dont hesitate to contact us with any questions or needs.
Thanks!
