Ducati Streetfighter / 1198 / 1098 / 848 / Multistrada 1200 Air Filter by BMC
This is one of the fastest and cheapest way to more HP. As with all internal combustion engines, the removal of airflow restrictions on the intake side will allow better volumetric efficiency of the induction system. This upgrade to a hi-flo filter is the single most meaningful upgrade you can do to your Ducati.
Check our site for other models and applications.
https://www.motovationusa.com/mvstore/Scripts/prodView.asp?idproduct=932
Reason: update
