Custom LED Electronic Motorcycle Blinker Flasher Relay - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com Classifieds!Graves Motorsports
Go Back   Ducati.ms - The Ultimate Ducati Forum > Site Sponsors > McCoy Motorsports
Old Jul 26th, 2010, 10:05 am   #1 (permalink)
Official Sponsor
Custom LED Flasher Relay, Now you can fix the flash rate on your motorcycle with our unique Plug And Play solution! That's right, the Custom Led Electronic LED Flasher relay directly replaces the stock flasher relay on most Yamaha, Honda and Kawasaki motorcycles! See the compatibility list below.
CUSTOM LED FLASHER RELAY FEATURES
For motorcycles with non-standard two wire flasher relays (not on compatibility list), this flasher relay can still be used by removing the connector and hard wiring it. Even three wire flasher relays can be replaced if one of the wires is a ground wire. This unit is guaranteed to replace any two-wire flasher relay and operate at the normal DOT blink rate for motorcycles with stock blinkers, or all LED blinkers or any combination of both. (Some Honda motorcycles have their OEM flasher relays integrated into other electronics and therefore can not be replaced). This flasher relay operates properly, at the standard DOT blink rate, from 0.05A to 10A loads (0.6 Watts to 120 Watts!) - which basically covers any combination of ALL blinker products on the market! FITMENT INCLUDES - Yamaha: YZF-R1, YZF-R6, YZF600, FZ-1, FJR1300. Honda: CBR1000RR, RC-51, CBR600F4i, CB919, ST1300, GL1500, CBR1100XX, CBR900RR, CBR929RR, CBR600F2, CBR600F3, CBR600F4, VTR1000R Super Hawk, VT600, 02-04 1800 C, 02-03 1800 R models, 02-03 1800 S models, 04-05 1300 C models, 03-05 1300 S models, 05 1300 R models. Kawasaki: ZX-10R, ZX-12R, ZX-6R(R) up to 04, Z-1000, ZXR1200(1100), ZZR1200, ZX1200, ZR-7. Suzuki: All late model GSXR's with two-wire replaceable flasher relays are also compatable, but require a hard-wire installation. Ducati: 996 - hard wire installation as follows when replacing OEM relay with our Electronic LED Flasher Relay: (Motorcycle Light Blue (LB) gets connected to the ELFR-1 Red wire Motorcycle Pink (P) gets connected to the ELFR-1 & Black wire Motorcycle Black is not used). Yamaha: Roadstar line, V-Star - hard wire installation as follows when replacing OEM relay with our Electronic LED Flasher Relay: (Motorcycle Brown wire to ELFR-1 Red wire and Motorcycle Brown/white stripe wire to ELFR-1 Black wire)
Thanks for your business!
Team McCoy Motorsports
Phone: 606-432-1556
Email: sales@tobefast.com
http://www.tobefast.com/c-led-electr...-10001075.html
Outrun is offline   Reply With Quote
Flasher relay hbr HyperMotard 11 Jan 17th, 2008 2:13 pm
Where's the flasher relay on a SC1000? wasp1000 Sport Classic 8 Jan 5th, 2008 9:59 am
Flasher relay issue blueagle Superbikes 5 Nov 18th, 2007 8:48 am
998 Flasher Relay Location? matchman Superbikes 7 Apr 11th, 2007 8:25 pm
Where is flasher relay Royb Sport Touring 1 Mar 31st, 2006 8:25 pm
