Here are some links and info on Galfer Brake Lines
Check out
www.tobefast.com for other applications
Galfer front brake lines for the Ducuti 1098 (07-08) models. Galfer's steel braided brake lines are made of PTFE 62 Dupont-Teflon , around the inner Teflon we have 16 strands of steel braided cable (most companies only use 12) that allows for almost 0 expansion effect when applying pressure to the brake lever.
http://www.tobefast.com/galfer-1098-...8-f-63998.html
Galfer hydraulic clutch line for the Ducati 1098 (07-08) models. Galfer's steel braided brake lines are made of PTFE 62 Dupont-Teflon , around the inner Teflon we have 16 strands of steel braided cable (most companies only use 12) that allows for almost 0 expansion effect when applying pressure to the brake lever.
http://www.tobefast.com/galfer-1098-...2-f-63998.html
Galfer rear brake line for the Ducati 1098 (07-08) models. Galfer?s steel braided brake lines are made of PTFE 62 Dupont-Teflon , around the inner Teflon we have 16 strands of steel braided cable (most companies only use 12) that allows for almost 0 expansion effect when applying pressure to the brake lever.
http://www.tobefast.com/galfer-1098-...9-f-63998.html
Galfer DOT 5.1 Brake Fluid. High performance brake fluid for all hydraulic disc and drum brakes. Comes in a 500ML bottle.
http://www.tobefast.com/galfer-51-br...4-f-63998.html
