Jun 18th, 2010, 8:41 pm
Extended Member
changing rotors on the Hyper. tips?
Hello gang,
So i bought some WSBK brembo rotors for my Hyper from a fellow board member, and I will attempt this most basic of mechanical undertakings... changing them out myself.
I thought I had a pretty simple job on my hands, until I started reading about pinched axles/wrong torque values/misaligned forks... the list goes on the more I search... and this is just for removing the wheel!
So, here are my basic questions, let me know if I'm missing any?
-do I need a torque wrench, or can I just hand tighten pinch bolts/rotor bolts etc? If I do need a torque wrench, where can I find values for each bolt that I need to work on.
-should I use antiseize or any other type of goop to prevent Ti bolts from permanently fusing themselves to the wheels?
-is there a specific order that I need to screw/unscrew each bolt. Left side, first, right side first?
-lastly, any other specialized tools outside of a front wheel stand/front pitbull?
thanks, sorry to be so damn needy... just don't want to screw something major up by assuming it's a simple job. I'll post pics when done.
ECM V is in 2014: Come celebrate 5 years of Ducati-related Shenanigans http://www.ducatieastcoastmeet.com/ . (And stop yelling or you'll wake up the sleeping underage asian cutie-patooties below)
2008 Ducshop Hyper S a.k.a. "Broke Beak Mountain" recovered from a 1.5 year coma after 2011 ECM crash on Cherohala SkywayDT996 "R" paintjob, (w/ Mag-uhne-sium TA-TAS!),Ducshop engine w/ Pistal pistons, EVO slipper, Ducshop stack, Ducshop light flywheel, Ducshop suspension setup, DP cams, 2-1 termi, PCIII, 1123cc bore, shift-tech alum. subframe, DPseat, DP damper, DP 520chain, Bonamici rearsets, resprung, Ducabike levers, Driven CF handlebar, Rizoma beltcovers/mirrors/grips/reservoirs, tail-tidy, powdercoated parts, carbon-ed everywhere
Jun 19th, 2010, 10:11 am
Extended Member
...calling all gurus, any gurus in the room? gurus please come to my office immediately for emergency Q&A session. i'll even take semi-gurus or wanna-be gurus.
Jun 19th, 2010, 11:48 am
The Road Beckons...
I am also curious as to putting everything back together. I have the forks off right now, have an axle alignment tool, and a torque wrench, now, what am i missing?
-Alex
-Alex
2008 Hypermotard 1100 S "Lola" - (SOLD)
2006 Multistrada 1000S DS "Duckie"
I'M ENGAGED!
Follow me on Descubre-La-Vida Blog
Jun 19th, 2010, 12:06 pm
WTF are you guys doin' over here? Git' back to the Hyper forum where you belong!  Do a search for "front wheel removal", "axle torques", "pinch bolts", etc. All the info you need is there. I would also suggest picking up a workshop manual disc off Ebay,they're cheap. Lots of good info here too. http://www.ctarna.com/Ducati/HyperMotard/
Jun 20th, 2010, 10:23 am
Extended Member
thanks for the info, I think (get a "malware" warning when I go to that link)
Also, was looking at buying my first NM-metric torque wrench... but these things start at $270 (snap-on)!!!... wonder how many wheel changes it would take to amortize the tools/work vs taking it in to the dealer who won't screw it up like I surely will the first few times.
Any particular type of torque wrench suggested? I went to home depot/lowe's but they just have english (non-metric ones) for about $110.
Jun 20th, 2010, 10:30 am
Hmmm, I bookmarked that page a long time ago. It was put together by ducati.ms member CTarna and contains the workshop manual, torques and more.
Maybe try to PM him?
Jun 20th, 2010, 10:39 am
Extended Member
thanks, I will.
I also read some reviews of torque wrenches and tried to familiarize myself with pro's and con's of each type. A good article is here http://www.webbikeworld.com/r3/torque-wrench/.
They compare a few types and recommend the precision tools C2: found it through nextag for $125 shippped: http://qualitytoolsforless.com/Produ...ProductID=2274
will probably take the plunge on this first tool... first step towards becoming a little bit of my own mechanic.
Jun 20th, 2010, 12:07 pm
Official Sponsor
If you don't want to buy a torque wrench you can rent one from your local Napa, autozone or advanced auto parts store. I think it is cheap or free. You just have to put down a deposit on it.
Jun 20th, 2010, 12:31 pm
Link works fine for me.
Jun 20th, 2010, 2:32 pm
Extended Member
thanks for that advice! will do, and a better option until i figure out which one I need.
hmm, maybe I have a "too-aggressive" corporate filter on my laptop.
