Gunsons Gastester - Ducati.ms - The Ultimate Ducati Forum
Old Apr 29th, 2010, 7:35 pm   #1 (permalink)
kaysystems's Avatar
Gunsons Gastester
Hi
Does anyone have experience using the Gunsons Gastester to test the CO reading of the exhaust.
I have one but I'm not convinced that it is very accurate.
I'd appreciate a short 'how to'.
From what I understand, one must calibrate for around 10 minutes to 2% CO, then use after the bike is properly warm. Is it that easy?
thanks
David
Ducati rider since '74
1966 250 Mark3
2004 ST3
kaysystems is offline   Reply With Quote
Old May 1st, 2010, 9:53 am   #2 (permalink)
ducsbill's Avatar
Can't vouch for the accuracy but the steps you listed are what I do. During the calibration you do need to make sure it's in clean air so don't try to calibrate it on a workbench next to a running motorcycle. The calibration will be a bit off.
Bill W.
2005 Ducati ST3, Black
2007 Ducati MTS 1100S, Black
Rantoul, IL
ducsbill is offline   Reply With Quote
Old May 1st, 2010, 11:40 am   #3 (permalink)
kaysystems's Avatar
I have to get the "really messed up" TPS sorted first. I think it was set whilst the throttle linkage rod was sticking part way open.
Then I'll look at the CO levels
David
1966 250 Mark3
2004 ST3
Old May 1st, 2010, 5:29 pm   #4 (permalink)
Images: 4
I have the Gunson Gastester. I won't claim it's a "high quality" tool. It's actually somewhat cheaply made and delicate but it seems to work.
Yes, power up the Gastester and let it stabilize for about 5-10 minutes. Then adjust the trim to read 2%CO. It'll drift with time but I don't bother tweaking it.
Here's the Gastester in action. I'll be breaking it out again as my 999S is due for another 6000mi interval service and I'm about to fire up my Monster project.
"Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat"
Silversled is offline   Reply With Quote
