Jul 20th, 2006, 7:07 pm
Safety wire question!
In the past I have lost the pins that hold my front brake pads to my calipers. (I have the front brakes that utilize two pins and two clips to hold the pads in place, from a 2001 S4 Monster mounted onto my '95 900 CR). Now, I would like to safety wire these buggers to keep it from happenening a FOURTH time... Could/would someone post a picture of their pins that they safety wired so I can figure out how to secure them to a fixed point on the bike??? Thanks for any help or pictures that you may provide!!
1995 900SS/CR (1996-2007)
2005 ST4s (2007-Present) Corbin Seat, Throttlemeister, Zero Gravity Double Bubble, DP Carbon Exhaust, ECU, K&N, 42 Tooth rear sprocket, Desmo Times fender eliminator, LuggageLocker tank bag, Givi top case, motobag, Stebel Compact Air Horn, EXOČ StormRider
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY
BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
Jul 20th, 2006, 7:30 pm
MultiModerator
This is off my old Aprilia, it uses the same two pin caliper as Ducati. Not the greatest picture, hope it helps.
Drill a 1/16" hole through the pin on both sides of the caliper. Then run safety wire between the two. I would the lost the pin on the rear caliper, and this seemed to stop it.
Vito
93 750SS - 10 Hypermotard EVO SP - 04 aprilia RSV1000 Factory
Jul 20th, 2006, 8:54 pm
you don't need to have them secured to a fixed point, the provided hole in inside the caliper body, you only need to wire them to each other fig 8 style. The can't escape.
Hoping to make it easier for you
Mal
insert witty comments here...
Jul 20th, 2006, 10:15 pm
By the looks of the picture, the pin is safety wired to itself, right? If that is correct do you still use the clip or, I assume, you only use the wire.
Jul 20th, 2006, 10:44 pm
MultiModerator
If you're talking about a clip opposite the side I safety wired, mine didn't have a clip. There was only a very small portion of the pin coming through the other side of the caliper. Yes the pin is wired to itself on either side of the caliper material so it can't come out. mals900ss suggestion of wiring them to each other sounds ok too.
Vito
