How to get a locked gas cap off with no key? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 12 (permalink) Old Nov 22nd, 2008, 10:17 am Thread Starter
Nove-R's Avatar
Question How to get a locked gas cap off with no key?
Just bought a used gas tank, XX9 that came with the gas cap installed and locked. I don't need the cap, I just need to get it off.
Seems that the easy thing to do is just get out the drill and a big bit and drill out the lock mechanism.
Before I do it though, I wanted to check to see if anyone else has done this and gain from your experience.
Anybody?
Streetfighers are built, not bought.
'05 999R
'00 955i/ GSXR1000 Streetfigher
'06 ZX-636 race bike
'08 KLR-685
'99 KZ-1000 Police Special
'84 VF500F Interceptor
999 or 998 Streetfighter (next build)
Nove-R is offline
post #2 of 12 (permalink) Old Nov 22nd, 2008, 1:40 pm
It should be fairly easy to open with a lock pick set. I am no locksmith, but with a pick set, and a little knowledge of how a lock works, you should be able to open the gas cap without damaging it or the tank in a few minutes.
Motobee is offline
post #3 of 12 (permalink) Old Nov 22nd, 2008, 2:06 pm
In my experience, gas tank locks seem to be the easiest to pick. You're better off picking the lock and taking the cap off than dealing with a bunch of shavings/debris in the tank later.
'98 ST2
'84 Kawasaki Gpz Turbo
mrturbozxj is offline
post #4 of 12 (permalink) Old Nov 22nd, 2008, 2:14 pm
Yeah, take it to a local locksmith, have them pick it...I just lost the keys to my 62 Ranchero, cost me $15 to have the locksmith pick the ignition lock...took him less than 5 minutes
mang441 is offline
post #5 of 12 (permalink) Old Nov 22nd, 2008, 11:28 pm
DEMON's Avatar
pull the pump out and push the lock back from the inside
DEMON is offline
post #6 of 12 (permalink) Old Nov 23rd, 2008, 1:04 am
Banned
Images: 15
+1... I did that when I got my 2nd 748 tank. The hole is pretty big and you can usually hit it with your finger no problem.
tye1138 is offline
post #7 of 12 (permalink) Old Nov 23rd, 2008, 12:44 pm
hawc's Avatar
I guarantee this will do the trick.
hawc is offline
post #8 of 12 (permalink) Old Nov 23rd, 2008, 3:30 pm
nuggets's Avatar
i'll have to look at my 749's cap, but i've taken a couple suzuki caps off by breaking off or dremeling around where the hinge pin in--and then pulling the pin out. i didn't worry about wrecking the cap because it's useless with a key
nuggets is offline
post #9 of 12 (permalink) Old Nov 23rd, 2008, 7:30 pm Thread Starter
Nove-R's Avatar
My thought exactly. I have a spare stock cap rattling around in a box that I do have the key for, and this cap was pretty corroded on the inside.
I just got out the trusty "OC Choppers" bit and had at it. I wanted to be sure that no damage would come to the tank itself when I drilled it out, but I rolled the dice, and none did.
Thanks to all that responded.
'05 999R
'08 KLR-685
Nove-R is offline
post #10 of 12 (permalink) Old Nov 23rd, 2008, 8:53 pm
VTGPDUC's Avatar
Maybe they change it.
Used to be that any Ducati key would open any tank of similar model. Ie. any supersport key will open any supersport tank. But I could be mistaken.
2006 749S (resurrected)
1995 900SSSP/track bike
2001 750SS/"rain bike"
1975 CB400F/Yoshima
1996 CR250R
2005 CR85R (for sale, still)
1971 Bultaco-project
2000 Z50R
VTGPDUC is offline
Human Verification
Rizoma Fluid Tanks & Ssr Gas Cap 4-sale PAKBIKES JC/PAK Bikes 2 Sep 20th, 2010 2:08 am
Gas Cap Replacement woody Sport Touring 3 Sep 20th, 2008 6:13 pm
Gas cap tech help race2win1 HyperMotard 1 May 9th, 2008 1:10 am
