Lanyard kill switch - Ducati.ms - The Ultimate Ducati Forum
post #1 of 3 (permalink) Old Feb 22nd, 2008, 6:10 pm Thread Starter
RockingM's Avatar
Lanyard kill switch
I don't quite like the term 'dead man switch"
Anyway, I'd need one for the land speed events if I run at Maxton.
Has anyone installed it? How to make it easily removable?
I really don't want it on the bike when not running an event.
Which wires are best to use? The ones to the stock kill switch or other?
I suppose I could splice in the lines with a crimp style blade plug and simply
remove the kill switch and plug the original wire back together.
Ideas greatly appreciated.
"Beware the lollypop of mediocrity; one lick and you suck forever. " Timothy Leary
“Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge.” EJ Potter
Robert
99 ST4 Red
2003 ST4s Red
1961 Velocette in 1953 Featherbed
https://www.facebook.com/BlackHorseLogging
RockingM is offline
post #2 of 3 (permalink) Old Feb 22nd, 2008, 9:04 pm
infoage1's Avatar
I wired one of these into a friend's M900 for the same purpose. He opted to have me hard-wire it in (solder), as he didn't want to risk having quick-disconnects coming apart at speed...
Were I to use a connector of some kind, I would use one that has a lock, or latch, of some sort on it to reduce the risk of having a problem.
I tapped into the kill switch, near the steering stem, and used epoxy heat-shrink over the connection. It is a really well made piece of equipment, and honestly doesn't look bad leaving it in place. He simply removes the lanyard leaving the kill-plug in place for the street.
http://www.powersportsfx.com/sa/p/MP...ill_Switch.htm
infoage1 is offline
post #3 of 3 (permalink) Old Feb 22nd, 2008, 9:27 pm Thread Starter
RockingM's Avatar
That's the one, and now that you cause me to take a second look,
it wouldn't look to bad left on the bike without the lanyard.
I just hope no one comes by and pulls the plug for laughs and I'm stranded.
Thanks again for the info on the wire in.
Robert
99 ST4 Red
2003 ST4s Red
RockingM is offline
Human Verification
st2/monster kill switch interchangeable? bigfudge Sport Touring 1 Jul 23rd, 2007 6:28 pm
998 Engine Turns But No Spark 998Pilot Superbikes 33 Jul 5th, 2007 6:02 am
2005 999 Sidestand kill switch problems Hawk Superbikes 5 Nov 22nd, 2006 12:59 pm
749 turn signal switch trivia: or why I hate boneheaded changes like this rustysrustyduc Superbikes 5 May 24th, 2006 5:50 pm
Can you I.D. this light switch? Could be SBK related.. but I don't know rustysrustyduc Superbikes 4 May 14th, 2006 1:59 am
