Clutchless shifting?? - Ducati.ms - The Ultimate Ducati Forum
Old Feb 9th, 2007, 8:49 pm   #1 (permalink)
st2brooke's Avatar
I had a buddy say he only uses his clutch for first gear, not for upshifts. Is he nuts? I always clutch, ever hear of this??
2006 Ducati 999s
2002 Ducati ST4s (traded)
2001 Ducati ST2 (sold)
2002 H-D FXSTDI Deuce (for sale)
1989 Honda GB500 Tourist Trophy (sold)
2009 Yamaha FZ6R (wife's)
st2brooke is offline   Reply With Quote
Old Feb 9th, 2007, 9:27 pm   #2 (permalink)
'bout the same as what I do, only I clutch for downshifting (just to be specific). Lots of guys I know do that.
'04 999
Mapless is offline   Reply With Quote
Old Feb 9th, 2007, 9:32 pm   #3 (permalink)
m1a1dvr's Avatar
Not using the clutch for upshifts is ok. What happens is the power going to the main shaft in the tranny is not spinning as fast as the gears. So there is not real lashing of the gears when you shift. Now down shifting is when you rin into problems. There is a heavy load when you shift down with out the clutch. The lower gears are spinning faster than the tranny shaft. That caruses then to grind when you shift. Basically after a while of that you will end up stripping the gears out.
m1a1dvr is offline   Reply With Quote
Old Feb 9th, 2007, 9:43 pm   #4 (permalink)
bc1
Yep, hardly ever use the clutch upshifting. I just back off the throttle for a mili-second and grab the upshift. Backing off unloads the trans and it goes right into the next gear. Quik shifters/power shifters, like the ones dyno jet and others sell does basically the same thing except electronically. When you move the shift lever, the quik shifter shuts off the fuel, or ignition, or a combo of both to unload the trans and allow the gear change to occur.
But like the others said this is for up-shifts only.
bc1 is offline   Reply With Quote
Old Feb 9th, 2007, 10:51 pm   #5 (permalink)
04749s's Avatar
Up or down i've never had any problems ,, just match the revs with a slight pause as you go . The only time i really use it is at stops and starts .
2001 ST2
998sFE
04749s is offline   Reply With Quote
Old Feb 9th, 2007, 11:04 pm   #6 (permalink)
Maximus-Speedicus's Avatar
Images: 67
shift away
shifting without clutch
quite often I'll shift without both ways, up and down. some of the downs
can be a little jerky but not often. sometimes my hand hurts a little from using the clutch, so it's a handy thing to learn, if you'll pardon the pun
Mal
I only lack THREE things to be a GP rider....
Talent, Ambition and Initiative
"Ergost yellicium mosticom finae speddicullus maximisan. Despitate ducati ergoni matchello"
Maximus-Speedicus is offline   Reply With Quote
Old Feb 9th, 2007, 11:40 pm   #7 (permalink)
dug
dug's Avatar
Yup. Not a problem, up or down. I do use it to go 1-2, tho, as it can get kinda jerky if I'm not mindful.
06 Sport1000 05 GSXR750
03 DRZ400S 99 CBR900RR (wife's)
93 CBR600F2 (in pieces)
_____________________________________________
www.ducati-owners-group.com
dug is offline   Reply With Quote
Old Feb 9th, 2007, 11:55 pm   #8 (permalink)
clutchless here on nearly all upshifts, but mostly into 3,4,5 and 6.
Clutch all the time on downshifts.
angie-r is offline   Reply With Quote
Old Feb 10th, 2007, 12:48 am   #9 (permalink)
88sporty's Avatar
Ive done both up/down shift w/o clutch. Some days however, I will use the clutch for every up/down shift. depends how I feel.
Downshifting you have to put downpressure on the shifter, when it matches ie: engine speed/tranny speed, it shifts by itself. However if you are going to fast, you can lock a rear tire up. Don't ask how i know this
96 900 SS/SP
Molon Labe
88sporty is offline   Reply With Quote
Old Feb 10th, 2007, 2:52 am   #10 (permalink)
bambam's Avatar
One more for upshifts
I use the clutch on downshifts mostly, hardly at all on upshifts...
Cheers,
Bill
'99 900 Supersport
bambam is offline   Reply With Quote
GP shifting (reverse shifting) with stock linkage? DanTheMan Superbikes 27 Oct 30th, 2007 4:28 am
Shifting gears !!!! Keyboard Superbikes 2 Jan 1st, 2007 7:00 pm
Clutchless shifting Lars Supersport 8 Aug 12th, 2006 8:05 pm
Throttle Position when clutchless Shifting WISCorse Superbikes 21 Aug 8th, 2006 8:30 pm
05 999, clutchless upshift, Misshifting to 5th? m3elmo Superbikes 3 Jul 9th, 2006 12:14 pm
