Jan 26th, 2007, 8:02 pm
EK Chains and their Screw Type Master Link
www.ducati-owners-group.com
Jan 26th, 2007, 10:32 pm
I have an '03 ST4s, bought in May of 2005. At the 600 mile service (900 actual miles) I had the dealer install a 42 tooth rear sprocket and EK chain.
I've put only 3000 more miles on it since then, but I haven't experienced any problems.
-Bob
Jan 27th, 2007, 12:44 am
Jon,
Have you seen this from Ducati?
Ducati Red: Part #'s
968331AAA 520 Pitch
968332AAA 525 Pitch
Special chain with 110 links and 525 or 520 pitch. Available in "Ducati Red" and gold.
Match with 6mm front and rear sprocket
Chris
2006 749 Tricolore FOR SALE
Jan 27th, 2007, 1:48 am
Yea, I saw those in my catalog. It's a RK chain sold by Ducati. I think I said Regina in my original post but EK and RK are the only ones I have found that make red.
Jan 27th, 2007, 7:12 am
Originally Posted by Dark_Daddy
968331AAA 520 Pitch
968332AAA 525 Pitch
The pitch is the same on size 520, 525, and 530. Same roller diameter too. You can actually use a 525 and 530 chain on 520 sprockets (but shouldn't). Only the width is different.
Just some chain trivia.
2001 ST4
BCM-built in 2004. 120RWHP and still running great after 33k. Thanks Bruce!
Jan 27th, 2007, 7:44 am
It looks to be what the aircraft industry calls a "Hi-Lock".
The nut has an extended collar built into it... as you tighten the screw it "rivets" the collar to the shaft. There is a groove made between the threaded nut and the collar. When the torque is correct the nut/collar snap apart with a very stubborn rivet type fastener left behind.
They are pretty neat! I would think they would work pretty well for a chain -especially for emergency repairs.
But, I've neve used the EK master...
Jan 27th, 2007, 10:30 am
See, that was my thought too!! No more special tools to install a rivet type link, but still has the same strength as a rivet link (so they claim) and you don't have to worry about a clip! Although, I see tons of guys all the time at the track and everywhere running clip types with zero problems at all???
