Feb 5th, 2012, 12:09 pm
Track day close to service interval?
So I am 1,600 miles from my 12k valve adjustment (I'm up on all other services). Would it be harmful to do a track day around the 12k mark before doing the valves? Would it be a waste of time to do it early?
1999 750SS
Feb 5th, 2012, 12:14 pm
I have a button.. BITCHES!
It won't hurt it. I did a track day on My SS that had 14,000 miles on the belts and NO valve adjust, well, ever. Just check Your belts for cracks, put some fresh oil in it, slap on some decent tires (they don't have to be the best), and have a good time.
Feb 6th, 2012, 9:42 am
It certainly wouldn't be harmful!
I did my 12k mile service like 400 miles early to do it before a track day, but I was due for belts as well. And it was my first track day so I was a little paranoid abotu the 2 year/12k mile belt change interval.
I personally feel like 1600 is a little early, but if it gives you piece of mind it certainly won't hurt.
If you decide not to do the 12k mile service early, and your still on the same oil from the 6k service, I would suggests an oil change and filter. The reality is with a good synthetic oil, it would probably be fine anyway, but a track day is going to put more heat and stress on the engine then a normal street ride. So if it were me and I had 4400 ish miles on the oil, I would change it prior to the track day.
Have fun at your track day, Ride Safe!
Blue Skies,
Dave
'05 SS1000ds
'02 748s
Feb 6th, 2012, 10:11 am
I am really anal when it comes to maintenance. The bike will have EVERY wear item replaced, and 100% new fluids and tires. I just don't want the valves holding me back, because I know my bike might be out of commission for a while.
Thanks!
1999 750SS
Feb 6th, 2012, 10:22 am
i will give you $1000.00 if you can blow that motor up at the track. just make sure theres oil in it before you start. have fun and dont crash those things are built like briggs and stratton five horse motas
Feb 6th, 2012, 9:23 pm
I understand where you are coming from. I am sort of from the same school, sticking to the schedule and worrying about making sure your baby is good to go. You will get plenty of advice, but, in the end you are making the choice. Do what you feel is right and will assuage your fears.
Official AxlJak Clutch and Water Pump cover tester. Work Great!
Feb 7th, 2012, 6:09 am
You will be lucky to put on 200 miles at a track day. Run it and get your service done when you get back. If everything has been maintained properly, you will be fine.
present
'03 Ducati 999 ('07-present)
'11 Harley Davidson Electra Glide FLHTP (hey, I get PAID to ride it!)
past
'99 Ducati 900SS ('01-'08)
'87 Yamaha FZR1000 ('91-'01)
'89 Yamaha FZR400 ('93-'97)
'89 Yamaha FZR600 ('89-'91, stolen)
'87 Yamaha FZ600 ('88-'89)
Feb 7th, 2012, 10:44 am
I understand that the bike wont explode at 12,000 miles if i dont pull over and check the valves. I know how hard track days can be on machines, and generally i am really easy on my bike. I think I will take it slow putting on miles up until the track day, and continue to be up on ALL other maintenance.
1999 750SS
Feb 7th, 2012, 9:24 pm
Do the service. If the bike is a 1999 chances are that the timing belts need to be changed (every 2 years, every one year if doing all track days/club racing). The valves will not move much but if a belt lets go you are screwed. Also, this gives the tech a chance to catch something that may keep you from riding at your track day.
Feb 7th, 2012, 9:41 pm
Yeah as I explained before all maintenance is up to date. The first thing i did was change the belts. EVERYTHING will be replaced. Spark plugs, fuel filter, etc.
As far as checking it over, about 2000 miles ago I brought it the mechanic that performed the 6k service. It was for a "safety" check as I had just gotten the bike.
It sounds to me like I will be fine.
1999 750SS
