carbon on intake valves - Ducati.ms - The Ultimate Ducati Forum
Old Jan 29th, 2012, 8:29 pm   #1 (permalink)
In the process of doing my valve adjustment I noticed my intakes valves were covered with carbon. Reading similar posts on the forum sounds common which seemed strange. That being said, what is an acceptable amount of crud on your valves before you pull the heads for a cleaning.
'01 ST4 Red
longdrive is offline   Reply With Quote
Old Jan 29th, 2012, 11:31 pm   #2 (permalink)
Old Cafe Racer
Images: 63
I don't clean mine, BP ultimate does it for me:
When I got the bike she was pretty carboned up.
Now when I look down the intakes she's all clean & shiny.
Products and services - BP Ultimate - BP Ultimate Unleaded - Why should i buy BP Ultimate? - Cleaner engine
Scroll down the page & watch this remarkable video.
davy-j
2000 748 57,095 km
2007 Cagiva Mito 125cc 2 stroke
1967/73 Triumph Daytona T100R Cafe Racer project bike (almost finished)
Sun's out, lets ride
davy.j is offline   Reply With Quote
Old Jan 30th, 2012, 11:12 am   #3 (permalink)
McFly's Avatar
Where do you get that fuel in the states? I have never seen that before, amazing how clean it is. I would use that if I could find it????
2009 Ducati 1198s "My first Ducati and I feel like I have starting ridding all over again"
McFly is offline   Reply With Quote
Old Jan 30th, 2012, 6:11 pm   #4 (permalink)
Trackday Junkie
Mospeada's Avatar
Just go to Pep Boys, buy a bottle of Redline's Complete Fuel System Cleaner, and dump the whole bottle in along with 3 gallons of gas. That will clean up the valves and the injectors.
Seafoam works well too.
"No doesn't mean no; 'giraffe' means no....."
http://www.socaltrackdays.com/
http://www.chuckwallavalleyraceway.com/
Mospeada is offline   Reply With Quote
Old Jan 30th, 2012, 8:39 pm   #5 (permalink)
I had a similar problem. I read in the warranty here in the States that fuel additives are not to be used.
Go figure.
stubbicatt is offline   Reply With Quote
Old Jan 31st, 2012, 1:02 am   #6 (permalink)
Old Cafe Racer
Images: 63
Don't tell them
davy-j
2000 748 57,095 km
Old Feb 1st, 2012, 3:30 pm   #7 (permalink)
Akkutz's Avatar
On the intake valves? Yeah, the joy of shower injectors. Not all carbon but alot of the crap "they" are putting in the fuel. The injectors fire even when the intakes are closed. So, a good fuel cleaner helps out. Ben Fox rec. the BG fuel cleaner, run i about once a month or so....
Akkutz is offline   Reply With Quote
Old Feb 6th, 2012, 9:35 pm   #8 (permalink)
Booster's Avatar
I am a firm beliver in Techron.
I am not a beliver in the mechanic in a can until this stuff. Originally I just ran it in bikes when the carbs where gummed up from storage. Saved me from several carb jobs just to clean them out.
The convincer for me, I had a refresh done on a 853 kitted bike with 30k miles. My mech wanted to know what i was running, he had never seen piston tops and valve stems so clean. I thought he was just pulling my chain until he showed me another motor, pistons and valves for comparison.
Official AxlJak Clutch and Water Pump cover tester. Work Great!
Booster is offline   Reply With Quote
where to find intake and exhaust valves? big bore complete rebuild Motoxs3th Superbikes 6 Dec 17th, 2010 11:03 am
D748 996 916 998 carbon fiber air intake tube carbon fiber covers Das Borgen Parts and Accessories 4 Jul 2nd, 2010 8:13 pm
MS4R valve clearances and intake valves dirty? carlosbarrios Ducati Motorcycle Chat 2 May 28th, 2008 10:17 am
Carbon on Intake Valves - with pics srg5150 Superbikes 1 Mar 6th, 2007 11:12 pm
Anyone have intake valves in front of them?= grendels_arm Superbikes 7 Jan 19th, 2007 1:00 pm
