Hard handling - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 29th, 2012, 9:35 am   #1 (permalink)
Hamood5005's Avatar
Hard handling
Guys is the monster696 difficult to handle in the corners ?!
Hamood5005 is offline   Reply With Quote
Old Jan 29th, 2012, 9:35 am   #2 (permalink)
Winchester Boy's Avatar
No.
How about you just get a big ol mug of STFU?!
Winchester Boy is offline   Reply With Quote
Old Jan 29th, 2012, 9:41 am   #3 (permalink)
Hamood5005's Avatar
Then why I feel it very heavy ?
Old Jan 29th, 2012, 9:44 am   #4 (permalink)
I don't know. What tire pressures are you running?
Old Jan 29th, 2012, 11:15 am   #5 (permalink)
Hamood5005's Avatar
I'm not sure buddy but I feel the handling so bad I can't turn easy
Old Jan 29th, 2012, 11:47 am   #6 (permalink)
mlukason's Avatar
Hamood5005, Check the tire pressures (check the owners manual, probably something like 32 psi front and 34 psi rear). Another thing to check is the steering head bearings...get the bike on a stand and get the front tire in the air. Move the handle bars from stop to stop...do they bind anywhere or is the motion nice and smooth?
Mike
2006 ST3
Bikes of the past:
1989 BMW K100RS ABS
1983 BMW R65LS (never should have let it go!)
1976 Honda CB750F
1976 Honda CB360T (the start of it all)
mlukason is offline   Reply With Quote
Old Jan 29th, 2012, 12:13 pm   #7 (permalink)
Do you mean the handling is heavy compared to other motorcycles, Hamood?
Tires are a good place to start and should be checked before every ride I think.
We're here for you and some people know a lot.
Not me though.
Old Jan 29th, 2012, 1:05 pm   #8 (permalink)
Ritlee's Avatar
Tire pressure being so important in handling, and if set to manufacturers recommendation. What would guide you to change it to higher or lower pressures. I know because of the nature of tires getting hotter on the track you should run slightly lower tire pressures.
Just what would determine why more or less pressure for the same riding conditions.
IE lays over too fast you...
or is slow laying over you...
'99 750SS
'07 Sportster 1200(sold)
'81 Honda CB750C (sold)
US Army Reserves, 14 years and counting
Ritlee is offline   Reply With Quote
Old Jan 29th, 2012, 1:16 pm   #9 (permalink)
I run 32 and 36 most of the time, but at The Gap I drop to about 26 and 28.
I'm not saying I'm right though.
Old Jan 29th, 2012, 5:56 pm   #10 (permalink)
Tripod's Avatar
It is worth having the bike properly set up. There are numerous discussions on this, but basically, if your sag isn't set right, bike can be a pig.
Setting rear ride height generally makes the bike drop into the corners faster/easier.
When I got my bike (used) it was a pig. The rear was too low, I don't know how the prior owner even lived with it, dropped the fron forks slightly, set rear sag, and it was a new bike.
Just saying, you don't know if the setup is right or not, but I'd guess not.
Mark - 2001 Monster S4 Senna
Being led astray by Wonway for 2 years.
Tripod is offline   Reply With Quote
What a difference in handling! Dennie Superbikes 99 Mar 28th, 2012 10:26 am
How hard is too hard to start a 1098? Noc748 Superbikes 36 Oct 19th, 2011 6:33 am
999 Handling thatmarine Superbikes 35 Apr 10th, 2009 11:41 pm
Best handling Duc? russh Superbikes 117 Sep 18th, 2008 10:34 pm
Handling 06 vs. 07 Frisson Sport Classic 17 May 9th, 2007 1:05 pm
