Closer rocker tool - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!SportbikeTrackGearMotorcycle.com
SportbikeTrackGear
Old Dec 4th, 2011, 7:59 pm   #1 (permalink)
Ric
Ric's Avatar
Closer rocker tool
Compressing the closers on my 900 or 944 are not a problem.But it's a different story with my 1100.The springs are a LOT stronger making it very difficult to change shims.Anyone else having this problem? Is there a rocker tool to make this easier?
2001 Goldwing 1800
2009 Hyper 1100S
Ric is offline   Reply With Quote
Old Dec 4th, 2011, 10:26 pm   #2 (permalink)
Not sure if the same tool can be used, but I just used this guy on my 996 and it worked great!!
Ducati 2 Valve and 4 Valve Adjustment Shim Kits
1999 996s
rtzx9r is offline   Reply With Quote
Old Dec 5th, 2011, 5:25 pm   #3 (permalink)
Ric, I have the tool that rtzx9r has displayed. Let me know if you would like to borrow it!
Chris
ChrisM is offline   Reply With Quote
Old Dec 5th, 2011, 6:33 pm   #4 (permalink)
Ric
Ric's Avatar
Chris
Thanks Chris.I have a tool just like that one.Your 4 valve springs are about the same tension as the 900 2 valvers.The springs in the Hyper 1100 motor are a LOT tougher than the others.There has to be some kind of tool that can hold the rocker compressed while changing shims.I might have to macgyver it.
2001 Goldwing 1800
2009 Hyper 1100S
Old Dec 5th, 2011, 7:51 pm   #5 (permalink)
No problem Rick, if you need any shims, I have a shim kit that would probably have what you need.
Chris
rocker pin removal tool ScrewDriver Superbikes 9 Dec 9th, 2010 12:14 pm
closer shim measurement tool 97supersport Supersport 3 Aug 13th, 2010 7:10 am
Measure Closer Shim w/o Tool? m3elmo Superbikes 15 Oct 16th, 2007 9:55 am
Closer Rocker Spring Install Proceedure Mike931 Ducati Motorcycle Chat 2 May 10th, 2007 12:34 pm
