Racing Batteries Lithium alternative? - Ducati.ms - The Ultimate Ducati Forum
Old Nov 30th, 2011, 7:51 am   #1 (permalink)
LondonDutch's Avatar
I've had little success trying to replace the OEM Ducati battery (YT12B BS) on my Sport Classic 1000 with 3 small RB12 lithium units wired in series from Racing Batteries and will now try a single unit, the RB400.
The 3 smaller units just made the starter click, and received wisdom was that the ECU needs more amps to wake up than my setup was providing, while my three cell stack may have been wired together with some resistance in the connectors, so I'm being told the RB400 will work.
Just for the record, Calum at Racing batteries has been extremely helpful, and keeps sending me batteries FOC. Assuming this works in the end, I'd rate them highly.
Has anyone had any experiences that may help me with my upgrade?
Thanks
LondonDutch is online now   Reply With Quote
Old Nov 30th, 2011, 4:40 pm   #2 (permalink)
Old Cafe Racer
Images: 63
Just get a Shorai.
davy-j
2000 748 57,095 km
2007 Cagiva Mito 125cc 2 stroke
1967/73 Triumph Daytona T100R Cafe Racer project bike (almost finished)
Sun's out, lets ride
davy.j is offline   Reply With Quote
Old Nov 30th, 2011, 5:34 pm   #3 (permalink)
protokultur's Avatar
Why did you do that? Did you mean in parallel? Because you'd be cranking at the amperage of the small battery in series.
protokultur is offline   Reply With Quote
Old Nov 30th, 2011, 5:34 pm   #4 (permalink)
TheX's Avatar
Images: 7
You need 4 cells (or 8, 12) for a 12vdc system.
Current Bikes: Aprilia RSV4 Factory for the street
'05 Honda CBR600RR Track Bike
"The trouble with internet quotations is that most are just made up" - Abraham Lincoln, 1864
TheX is offline   Reply With Quote
Old Nov 30th, 2011, 6:53 pm   #5 (permalink)
Have a friend with who went through 2 Shorai batteries on his 1198 and they have caused him nothing but problems. First one shorted out. And the 2nd one will give a 14v one min and then the next it will be 0v. And then when you put a tender on it to charge it will go back up to 13+v in a min of charging. Definitely something off with it. I've been using a Ballistic on my 1198 and it works wonders. Just don't use it in below 40 degree weather or you'll have a hard time cranking the bike.
Originally Posted by davy-j View Post
Just get a Shorai.
pcguru2k is offline   Reply With Quote
Old Dec 1st, 2011, 12:23 am   #6 (permalink)
Old Cafe Racer
Images: 63
No problems here, the Shorai just keeps keeping on, good as gold.
davy-j
2000 748 57,095 km
Old Dec 2nd, 2011, 5:43 pm   #7 (permalink)
It clearly says in the Shorai instructions that you cannot use a tender or trickle charger on them
"Ducati: designed by art students, assembled by art students"
1999 748 Monoposto rebuilt from the repainted (red) frame up. Marving/Termi slip-on. Black 5 spokes. 996 motor rebuilt by Fox Performance. MBP valve collets, MBP rockers, STM adj. cam pulleys. 749R Slipper clutch. TNT Breather. MPL clutch slave. Heli bars. Speedymoto kukri/area 51 clutch. Tasty carbon bits sprinkled throughout.
Desmo Soundtrack is offline   Reply With Quote
Old Dec 2nd, 2011, 6:03 pm   #8 (permalink)
DuckMan's Avatar
I was just reading the instruction that came with mine and I don't see that. That only outstanding warning I see is to not use a high voltage "anti-sulfation" type unit. It says that any standard lead-acid charger with peak charge outage of 14.4 volts or less my be used.
I checked my Battery Tender and it only puts out 13.4 volts while charging.
It does however say that it shouldn't be necessary to charge it even if it sets for up to a year.
Mike
DuckMan is online now   Reply With Quote
Old Dec 3rd, 2011, 1:53 am   #9 (permalink)
I'm going to verify next time I get up to my cousin's where the box is, but I'm fairly sure I'm not making this up.
Old Dec 3rd, 2011, 8:13 am   #10 (permalink)
DuckMan's Avatar
Well, your right. The box does state it differently that the included instruction sheet.
Mike
Lithium Battery for ST macraige Sport Touring 5 Jul 16th, 2011 7:42 am
Lightweight Lithium batteries Revelstoker Apparel and Accessory Chat 9 Feb 14th, 2011 4:50 pm
Lithium Ion batteries Armen Supersport 5 Jan 29th, 2011 8:18 am
alternative to high priced yuasa batteries? - 94 Ducati M900 aa240sx Monster 0 May 28th, 2008 3:04 pm
