Non O Ring Chain - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Oct 30th, 2011, 7:28 pm   #1 (permalink)
RockingM's Avatar
Non O Ring Chain
I need a new chain for the 750GT and it's a 530.
There may be a clearance issue with an o ring chain and I've decided to go non O Ring. It's been 30 some years since I ran a non O ring. What's the best one?
This is probably going to be like an oil thread if anyone answers.
"Beware the lollypop of mediocrity; one lick and you suck forever. " Timothy Leary
“Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge.” EJ Potter
Robert
99 ST4 Red
1973 750 GT
RockingM is offline   Reply With Quote
Old Oct 30th, 2011, 8:00 pm   #2 (permalink)
Dmitry's Avatar
couple of my bikes have a 530 chain and I found out that the price of the same 525 chain is almost half of 530, probably due to popularity, tried to convert both bikes but got wrong sprockets and gave up. I did bite a bullet and used the o-ring chain, IIRC ended up paying about buck-fitty for a chain.
The one comparable to the one I bought for the Duc was two-fitty, some fancy X or W ring chain
I made my comparison using the chart in Tucker Rock catalog, it as wear index listed for every chain, I can take a look tomorrow...
what's the 750GT, the Water Buffalo?
Dmitry is online now   Reply With Quote
Old Oct 30th, 2011, 8:26 pm   #3 (permalink)
RockingM's Avatar
Ducati round case bevel head 750GT.
the bike was original with the non O ring 530, O ring 530 is wider by a good bit than non O ring. Which will put it pretty close, closer than I'd like to
the inner side of the case. So, was wondering if anyone had a good non O ring chain to suggest.
Robert
99 ST4 Red
1973 750 GT
Old Oct 30th, 2011, 9:00 pm   #4 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Diamond, made in America and the only chain my buddy races with .
Diamond 530 Standard Chain | Rocky Mountain ATV/MC
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
va duc is online now   Reply With Quote
Old Oct 30th, 2011, 9:03 pm   #5 (permalink)
Dmitry's Avatar
I was thinking this GT750, mine was grey
Old Oct 31st, 2011, 4:11 pm   #6 (permalink)
RockingM's Avatar
I'll check it out Max. My local parts guy races dirt bikes and I think lots of those are using non o rings.
Robert
99 ST4 Red
1973 750 GT
Old Oct 31st, 2011, 4:22 pm   #7 (permalink)
vf1000ride's Avatar
Why not a D.I.D standard chain.
D.I.D. Racing Chains and Dirt Star? Rims
'07 SC1000 Biposto
DP race ecu, uncorked termi's, evap can fell off
shortened front turn signals, Fleda dual row tail chop
Rizoma fluid cups, Evoluzione clutch slave.
Traxxion fork cartridges and springs,
TPO Beast intakes. 42t DP alloy sprocket
Wasp TMSD, Dietrich gauge brackets
vf1000ride is online now   Reply With Quote
D.I.D X-Ring chain question mainframe Superbikes 9 Jun 20th, 2011 9:40 pm
DiD ERV3 520 X-Ring Motorcycle Chain RidersDiscount Riders Discount 0 Aug 6th, 2010 9:38 am
o ring chain lube anatak Supersport 3 Aug 2nd, 2010 2:19 pm
O-ring material coming off chain Gilles Ducati Motorcycle Chat 7 Jul 24th, 2009 12:04 pm
520 X 100 LINK hd o-ring chain gsxr750h Ducati Motorcycle Chat 1 Nov 25th, 2006 5:30 am
