Frame Powdercoating... - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Motorcycle.com Classifieds!
Old Oct 18th, 2011, 12:31 pm   #1 (permalink)
galaxy's Avatar
Images: 27
What do you do with the VIN decal if you strip one down to the frame to take to the powdercoater??
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Oct 18th, 2011, 1:11 pm   #2 (permalink)
Artistimo's Avatar
They can mask it off. Otherwise screw the sticker the frame is stamped anyway.
2001 748 Custom
2002 998s
2005 999 RS project in 6,739 pieces...
2006 999 Custom
Artistimo is online now   Reply With Quote
Old Oct 18th, 2011, 1:37 pm   #3 (permalink)
Spezjag's Avatar
The paintters should have techniques (sprays, etc.) that will allow them to safely remove the VIN sticker to re-apply it aafter the frame is re-painted. If they don't, consider looking for another painter - this kind of issue is pretty standard in the auto-painting industry.
Gary
Brought to you by the Committee to Re-Elect Godzilla
He kicked Ass in Japan, He'll Kick Ass in the UN!
Spezjag is online now   Reply With Quote
Old Oct 18th, 2011, 4:26 pm   #4 (permalink)
Dmitry's Avatar
Have them mask off the stamped VIN on the head tube, stamping is pretty shallow and I had to grind off the powder to have it exposed after my frame was PC'd.
If they can remove the masking tape after the color goes on but before they clear the frame it will be the best option.
Dmitry is online now   Reply With Quote
Old Oct 18th, 2011, 4:37 pm   #5 (permalink)
JDP
When my 749 frame was powder coated, i had the same concern. The powder coater said not to worry, as it is a lite enough coat to still have serial numbers exposed. They were right.
JDP is offline   Reply With Quote
Old Oct 18th, 2011, 8:06 pm   #6 (permalink)
Dmitry's Avatar
I told my PC guy to mask the numbers and he did mask ... the production date
so this is what my VIN looked like
Old Oct 19th, 2011, 9:19 am   #7 (permalink)
DME3's Avatar
Be sure they mask or cover the pars where the stearing bearing sits and all locations where there's thread for bolts etc.
Ducati 900SL MK I n° 92 | Ducati 900SS '94 Trackbike
DME3 is offline   Reply With Quote
Old Oct 19th, 2011, 9:41 am   #8 (permalink)
ZDM
Super Senior Poster
Is that powder or paint? Would you happen to know the paint manufacturer and color code, or is it just PPG "Ducati racing grey". Thinking about getting my frame redone when I change the bodywork over to yellow.
ZDM is online now   Reply With Quote
Old Oct 19th, 2011, 6:40 pm   #9 (permalink)
Dmitry's Avatar
it was custom mix, he matched it to the original subframe (i have a spare) 3 layers of powder: grey base, "sparkle" and then clear. If I was to do this again I would make sure that he uses less powder.
They were pretty good about plugging the holes and covering every surface where bearings or bolts go in, just had to point them out
diy powdercoating help wanted ihighro11eri Superbikes 2 Dec 30th, 2009 9:26 pm
powdercoating at home He Man Monster 5 Dec 1st, 2008 4:25 pm
Powdercoating jdb Ducati Motorcycle Chat 5 Apr 4th, 2007 7:25 pm
Frame powdercoating question???? skeezer541 Superbikes 18 Feb 12th, 2007 8:05 pm
