DP Light weight flywheel problems - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Oct 14th, 2011, 1:01 am   #1 (permalink)
I just put a Ducati Performance light weight flywheel on a Ducati DS1100 2 valve engine with wet clutch.
The DP part # for the light flywheel is 964575AAA. It is said to fit all modern 2 and 4 valve Ducati engines.
The problem I am having is that when I tighten down the large central nut that holds the flywheel to the end of the crank shaft I loose the free wheel of the starter clutch.
The starter clutch free wheels when turned CCW until I start torquing down the main fastening nut.
If I understand it correctly I should still have the starter clutch free wheel when the flywheel assembly is turned CCW even when the unit is tightened down to full torque specs.
Am I wrong? or am I missing something ???
Any help with this is greatly welcomed.
thanks
daotoys1 is offline   Reply With Quote
Old Oct 15th, 2011, 10:40 am   #2 (permalink)
thanks
when you turn it ccw it should spin freely from the starter gears
boatman is offline   Reply With Quote
Old Nov 5th, 2011, 2:20 am   #3 (permalink)
Nicoloff's Avatar
Do you have the correct spacer? Dp came with new spacers. I have the instructions if needed.
Nicoloff is offline   Reply With Quote
Light Weight Flywheel for 748 mc_sahib32 Superbikes 21 Jul 17th, 2009 10:31 am
Light Weight Flywheel JDuc Supersport 20 Apr 16th, 2009 6:15 pm
Light weight flywheel gunning Superbikes 11 Oct 19th, 2007 9:30 am
Light weight flywheel brinkdakid Superbikes 3 Jun 7th, 2006 9:53 am
Light-weight flywheel st2lemans Supersport 6 Jun 4th, 2006 11:23 am
