Sep 19th, 2011, 9:27 am
Ducati on a Truck?
I was unsure whether to buy a Ducati or keep my current bike. I just crashed, I am fine, my bike is not. So now is a good time to buy.
I have a Dodge Ram, and plan to buy a ramp today to get my bike home. I have no problem just dumping a crashed Jap bike onto its side in my truck bed and driving 10 miles home. But I would hate to treat a new (to me) Ducati the same way for a 100+ mile ride. Any ideas?
Sep 19th, 2011, 9:30 am
Seņor Member
I also have a Ram 1500. A bar harness and ratchet straps do quite well holding the bike vertical in the bed with the tailgate down. I have driven thousands on miles with bikes secured using my bar harness and tie down hooks in my trucks.
Doug
11 MS1200S Touring+
05 ST3
98 900SS FE
95 900SS CR
Sep 19th, 2011, 9:31 am
It'll be fine, I use a wheel chock and strap the bike down in my truck.
Current Bikes: Aprilia RSV4 Factory for the street
'05 Honda CBR600RR Track Bike
"The trouble with internet quotations is that most are just made up" - Abraham Lincoln, 1864
Sep 19th, 2011, 9:35 am
The Canyon Dancer (bar harness) and four tie down straps has worked very well for me.
Michael
'07 ST3s ABS
'03 DR-Z400
'01 VFR800FI
Sep 19th, 2011, 9:45 am
You don't even need a chock. Put it in dirtbike-style with the front wheel in the corner of the bed and two tie-downs. The bike will ride diagonally in the truck bed.
'99 900ss
'08 DL650
'97 XR650L
Sep 19th, 2011, 9:53 am
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Sep 19th, 2011, 10:56 am
Same here but make sure you compress the suspension somewhat before tightening your straps. They won't looson up as you drive if you do. Brought my 999 out to CA from MT that way over Donner Summit and it stayed in place perfectly.
Ride em if ya got em...
Sep 19th, 2011, 2:58 pm
I have a Ram 1500, and carried a monster and a 999 on the back - back and forth Austin/Houston (200 miles each way ). In gear, Put in front end first straight against the bed. Thighten ratchet straps enough were the front suspension is compressed nicely. Strap the rear with 2 straps to the corners of the truck. has never moved/shifted on me.
Matter of fact, I was short the rear straps once, and successfully transported the 999 strapped only by the handlebars (rear end was free). - It never shifted even then.
Sep 19th, 2011, 4:27 pm
It depends on what the bed surface is. I'd do it with Rhino coating, but not with painted steel. What eventually happens is that the front wheel works its way to one side and slacks the tie down and over it goes.
The easiest and cheapest solution would be a cheap tubing wheel chock bolted to a 2' X 2' piece of plywood with a rubber mat between it and the bed. It's a lot less expensive than a fairing and gas tank. In my truck and trailer, I use Pingel chocks that snap into buttons bolted into the floor.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
Sep 19th, 2011, 4:29 pm
Get a chock/stand, tie downs, and some old tires and you're good to go!
--M
"Speed has never killed anyone, suddenly becoming stationary...that's what gets you." - Jeremy Clarkson
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Ducati truck
Artistimo |
Ducati Motorcycle Chat |
9 |
Nov 12th, 2008 11:13 pm |
ducati stickers on my truck
kerry |
14 |
Feb 9th, 2008 4:15 pm |
