Shifting with or without the clutch??? - Ducati.ms - The Ultimate Ducati Forum
Old Sep 16th, 2011, 12:16 pm   #1 (permalink)
I have my first Ducati engined motorcycle. It is a new BIMOTA Tesi 3D LE with a Ducati DS 1100 2 valve engine. The bike comes with a wet clutch, but Im thinking Ill change this to a dry slipper clutch ( or at least put a wet slipper clutch upgrade in the drive line).
My question(s) are regarding the use or non use of the clutch when shifting the transmission gears going either up or down the gears. Im asking because I am not at all familiar with Ducati engines and know nothing about their reliability.
Is is safe to do clutch less gear changes with the Ducati DS 1000/1100 engines???
Im looking for any constructive information about this topic. Any replies are welcomed.
Im not planning of racing the bike, nor will it ever see a track, but it will be used for aggressive paved canyon riding in the Rocky Mountains of Colorado where 90% of my riding is done.
I should mention that Im an older rider ( Im 57 and started riding when I was a very young child). I was brought up taught to always use the clutch when shifting both up and down the gears and for bikes built in the 1960s and 1970s this was the norm for almost every type of bike except for racing where clutchless shifts were used with throttle modulations to match the engine speed to the drive line. Doing shifts without the clutch was considered harder on the bike but was worth the risk since in racing the goal is to try and win even at the cost of abusing the bike more.
Im guessing that there will be 2 main camps on this issue; on one side will be the riders who believe that the clutch should always be used, and on the other end of the discussion will be the riders who feel that using the clutch just slows one down.
My aim here is to learn more about what will maximize the reliability of my first Ducati engine. So any help in this regard is welcomed.
thanks
daotoys1 is offline   Reply With Quote
Old Sep 16th, 2011, 12:25 pm   #2 (permalink)
Sport999's Avatar
I'm not altogether sure that the type of motor makes any difference in clutchless shifting. I've been doing it on upshifts only for years on all my bikes and most recently with my new 999. Never had a problem. Slight off throttle and preloading the shifter (but not necessary) makes the shift smooth and quick.
Ride em if ya got em...
Sport999 is offline   Reply With Quote
Old Sep 16th, 2011, 6:02 pm   #3 (permalink)
Mate....you answered your own question didn't you? Things haven't changed...then and now...
Originally Posted by daotoys1 View Post
Doing shifts without the clutch was considered harder on the bike but was worth the risk since in racing the goal is to try and win even at the cost of abusing the bike more.......
thanks
Bollocks...
They still put clutches in bikes don't they? Race bikes even...don't think those boogery engineers just do it to keep the left hand from getting bored do ya? Use it/don't use it. Check your oil screen for shinny magnetic bits at your first oil change...you'll know how it's holding up ...go from there.
Cheers..keep us posted.
Ignatius_Riley is offline   Reply With Quote
Old Sep 16th, 2011, 11:02 pm   #4 (permalink)
GrandpaDuck's Avatar
If you're trying to maximize reliability/longevity and not trying to eek out every last 10th on the track, why risk clutchless shifting?
1993 888 SPO
1993 900 SS
GrandpaDuck is offline   Reply With Quote
Old Sep 16th, 2011, 11:24 pm   #5 (permalink)
bpracer's Avatar
On the street, I almost always use the clutch between 1st and 2nd gear, but other up-shifts, it just depends. I find it easier to up-shift without the clutch when the revs are higher. The slower you shift, the harder it is to do without the clutch. At least that is my observation.
At the track, even with my extremely limited talent, I don't even think about using the clutch for up-shifts. It's a piece of cake.
edit - This applies to both my 848 and my DS1000 powered PSLE.
06 PS1000LE Zard's, Hyperstacks, PCIII, 999 wheels and calipers
09 848 LeoVince/Fat Duc, Ohlins TTX and fork kit
65 Mustang Vintage Road Racer
bpracer is offline   Reply With Quote
Old Sep 17th, 2011, 7:40 am   #6 (permalink)
Tripod's Avatar
Originally Posted by Ignatius_Riley View Post
Bollocks...
Sure they still put clutches on bikes, it would be pretty hard to get going from a dead stop without one. But I have clutchlessly shifted both up and down for years. I'ts only harder on the bike if you don't know what you are doing.
Tripod is online now   Reply With Quote
Old Sep 17th, 2011, 12:37 pm   #7 (permalink)
SP3
SP3's Avatar
Images: 6
Usually no clutch after the 1-2 and none back down to 1. Depends on my mood. No slipper.
1991 851 SP3
1966 250 Monza
1999 Moster 900 City (not so much City anymore)
SP3 is online now   Reply With Quote
Old Sep 17th, 2011, 2:11 pm   #8 (permalink)
Kierownik1's Avatar
Images: 27
same here, clutchless upshifts is 100% safe if don properly.
Kierownik1 is offline   Reply With Quote
Old Sep 17th, 2011, 3:04 pm   #9 (permalink)
One of my other bikes is a SV650 with 32,000 miles with countless clutchless upshifts, never any issues.
From what I've read, seen, and experienced I've never known clutchless upshifts to cause any damage or excess wear.
I do use my clutch on upshifts, depends on my mood. I use the clutch on downshifts to rev-match.
SD 999S is offline   Reply With Quote
Old Sep 17th, 2011, 3:58 pm   #10 (permalink)
SP3
SP3's Avatar
Images: 6
I should have been more specific with my post: I don't use the clutch on downshifts when the pace is low. Cracking the throttle just a bit is all that is needed to match revs in that case. When the pace picks up = clutch on downshifts, yes.
1991 851 SP3
1966 250 Monza
clutch issue (shifting from 1st to 2nd) ph0ust Ducati Motorcycle Chat 5 Jun 25th, 2010 12:26 pm
shifting without clutch fidelio Superbikes 18 May 12th, 2010 9:40 am
clutch when shifting or downshifting? Ducati4ever Superbikes 30 May 22nd, 2009 9:12 am
Shifting without grabbing the clutch 99_Uomo Superbikes 10 Feb 15th, 2007 1:19 am
shifting without clutch stickcar1990 Superbikes 10 May 30th, 2006 12:58 pm
