Depends on which model you got. There are things to know about each. Couple things I know for sure:
On the HD cameras with the SD cards, make sure you use the type and brand suggested at Go Pro's website. They've done extensive testing and found which cards perform best. (I believe Patriot - class 4 - 16 gig is one of them...)
On the non-HD's that use regular batteries, use Energizer Lithium batteries only. Standard alkaline batteries don't handle vibration and temperature changes well, and the camera might not always record properly...
