Advice on macro lens. - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Photography
Old Oct 31st, 2011, 6:15 pm   #1 (permalink)
Im pretty new to photography and have owned an entry level dslr camera for a year.Canon 450 eos. I have a tripod and I am looking to take some real close ups of my marine tank. Fish and corals. I dont want to spend more than I need for a lens that I will not use much , so , what macro lens would you advise . Bear in mind that I am a beginner and need something easy. Thanks for any advice.
06 999R
ducati2242 is offline   Reply With Quote
Old Oct 31st, 2011, 7:20 pm   #2 (permalink)
Moderator
DUCeditor's Avatar
Images: 5
A "real" macro lens such as Canon's EF-S 60mm 2.8 is more than a lens that focuses closely. It also has a flat field, very even illumination, and exceptional corner to corner sharpness.
But Canon makes several zoom lenses with amazingly good close focusing ability. One of these is the standard "Kit" 18-55mm.
When I first bought my Canon small frame SLR I bought both of these. During tests I sometimes could not tell which of the two I had used.
Now that would not have been true if I had been shooting a flat subject, but for rounded objects relatively well centered in the frame (such as flower photography) it was.
Interestingly the far more expensive 18-85 EFS lens is nowhere near as good in "macro" mode.
-don
DUCeditor
Ducatis Unlimited Connection
www.duc.bz
"If I knew what an iconoclast was I'd probably be against that too." -Chabis Yadofsky
`07 GT1000 "Sommessa Donna" (Quiet Lady)
`93 900SS "La bella Rossa" (The Beautiful Red)
DUCeditor is offline   Reply With Quote
Old Nov 1st, 2011, 4:35 am   #3 (permalink)
SS904's Avatar
Not really into macro myself, but I've viewed shots taken with macro extension tubes that are pretty interesting. You add a "spacer" (the tube) between the body and whatever lens you're using and it allows for closer minimum focus distance. Not sure how well a kit a zoom would work. Many seem to favor the inexpensive 50 1.8 MK2 for this task. The tubes come in different sizes equating to differing magnification factors. The Canon branded ones are a bit pricy for what amounts to hollow tubes with lens mounts and electrical connections, but there are some very inexpensive options around as well. I assume the least expensive will have you fully manual, as in no auto focus or aperture control, but I haven’t looked into them that deeply.
A quick Google search for Macro Tubes brought this up. Neat run down.
Macro Extension Tubes & Close-up Lenses
This article discusses a few other Macro options, but the tubes seem to be the least expensive, and on the photo forums, the most popular short of an actual macro lens.
Anyway, maybe a decent way to get into macro for cheap before dropping big money on that special built lens.
Dan.
A man said to the universe:
"Sir I exist!"
A sense of obligation."
Stephen Crane
SS904 is offline   Reply With Quote
Old Nov 1st, 2011, 6:05 am   #4 (permalink)
Still needs a life.
Bill_Anderson's Avatar
Images: 19
You may want to check out the Tamron line. They offer a lower priced, after market alternative to the name brand Canon or Nikon lenses.
Tamron -60mm F/2(Model G005)
Old Nov 1st, 2011, 6:33 am   #5 (permalink)
Moderator
DUCeditor's Avatar
Images: 5
One nice thing about that lens is the F2 aperture. Not that you'd likely use that for actual macro shooting -- the depth of focus would be zilch. But a 60mm lens on a small sensor Canon camera makes a near perfect "Portrait" lens. I.e, one whose perspective neither flattens (as a tele would) or exaggerates features (as do so-called "standard" or wide angle lenses).
The F2 aperture would allow for lovely soft backgrounds. Unknown to me, however, is the look of the lens' bokeh -- its out of focus highlight appearance -- another critical aspect for portraits and many other types of images.
-don
DUCeditor
www.duc.bz
Old Nov 1st, 2011, 12:19 pm   #6 (permalink)
Thank you for your help. Im going to try a tube as they are so cheap I cant loose. If I like the macro photo I will then go for the 50mm macro lens. I will probably buy the one designed for the eos as like I say I need it easy. I find spannering my duke much easier to understand.
This is as close as I can get with my standard canon 18/55 that came with my camera. This was set to close up with everything on auto Ill take the same photo when the tube comes and post it here.
06 999R
Old Nov 4th, 2011, 5:34 pm   #7 (permalink)
Still just fiddling but I picked up a sigma 70-300 with a macro function. Not brilliant but I know they are getting better. You should see my bad ones.
06 999R
Old Nov 6th, 2011, 9:40 pm   #8 (permalink)
mlukason's Avatar
There are three mainstream options for you 2242: macro lens, extension tubes, and close focusing filters. I use all three, each has their own pros and cons. The lens will give you the greatest depth of filed (great for your corals!) but will be on the expensive side. The close focusing filter is simply a lens element mounted in a filter ring. When attached to your lens (works best with telephotos) the closest focusing distance is reduced therefore the subject is "magnified." I use a Canon 500D (canon 500d lens). Extension tubes will give you some great magnification but have really shallow depth of field. You can get some great effects though. I would recommend the Kenko brand rather than Nikon or Canon...as extension tubes don't have any optics...just a simple spacer between the camera and the lens.
Good luck!
Mike
2006 ST3
Bikes of the past:
1989 BMW K100RS ABS
1983 BMW R65LS (never should have let it go!)
1976 Honda CB750F
1976 Honda CB360T (the start of it all)
mlukason is offline   Reply With Quote
Old Nov 7th, 2011, 1:56 pm   #9 (permalink)
SpeedLimit?'s Avatar
Is it the lens with macro mode only for 200-300mm range? I was also looking at this lense as well as the Tamron 28-300mm lens for possible additions to my collection. More photos and feedback whenever you find the time please.
Check out my work @ http://www.flickr.com/photos/alexandre1983/
SpeedLimit? is offline   Reply With Quote
Old Nov 7th, 2011, 2:30 pm   #10 (permalink)
Yes it is only 200 to 300 Their is a fix for this but as of yet I havent plucked up the courage to do it but given time I will.
Macro Ringnikon | Camera Lens Blog
Good luck!
I have ordered an extension tube, There so cheap, but it hasnt arrived yet.
06 999R
Pictures with the new lens therabbit14 Photography 20 Aug 3rd, 2011 1:22 pm
Macro Pic's Tard Photography 8 May 11th, 2011 4:05 pm
Macro Tripods buell2duc Photography 6 Nov 9th, 2009 9:16 am
Cleaning the lens II desmodrone Superbikes 2 Jun 20th, 2008 7:10 pm
which lens... seabass74 Photography 10 Aug 31st, 2007 11:05 pm
