How do you jazz up boring lighting? - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Photography
Old May 4th, 2011, 10:59 am   #1 (permalink)
CrimsonCloak's Avatar
I took some practice shots a few weeks ago at a cold overcast track day. Do you guys have any tips for making drab light more exciting? They just don't have the pop of a nice sunny day.
For example...
I tried to do the old remove the saturation of everything and add some emphasis to a bright color since the shot is fairly grey anyhow.
M1100
CrimsonCloak is offline   Reply With Quote
Old May 4th, 2011, 11:48 am   #2 (permalink)
Still needs a life.
Bill_Anderson's Avatar
Images: 19
It goes without saying that most of my photos during this La Nina winter and spring have been taken with less than ideal lighting conditions. Rather than try to do anything to improve the light, I have worked on taking subdued photos which are almost monochromatic.
Old May 6th, 2011, 2:15 pm   #3 (permalink)
Moderator
DUCeditor's Avatar
Images: 5
For example...
Since photography is "writing with light" doing shots like this on a dull day is like trying to do an exciting drawing using a dull pencil.
Your approach as described is the right one. I'd just have risked being a little bolder. I'd use the entire range from black to white as a starter (that's the very thing that makes bright sunlight so exciting, an also so challenging. There go the shadows!) and then I'd risk blowing out the colors. To whit...
-don
DUCeditor
Ducatis Unlimited Connection
www.duc.bz
"If I knew what an iconoclast was I'd probably be against that too." -Chabis Yadofsky
`07 GT1000 "Sommessa Donna" (Quiet Lady)
`93 900SS "La bella Rossa" (The Beautiful Red)
DUCeditor is offline   Reply With Quote
Old May 24th, 2011, 12:18 pm   #4 (permalink)
Nice shot...try overexposing and adding some contrast...if you're using photoshop you can narrow the levels or steepen the curves.
twinthin is offline   Reply With Quote
Old May 24th, 2011, 1:39 pm   #5 (permalink)
RUNnDUC's Avatar
Images: 13
Try “low key exposures”.
Proud owner of a 02' ST4s (BB) grey, the stealth color.
________________________________
My old ride is swinging past Pluto, other rides, some looking out, some looking in, some repairing of others and sadly the R/D on two broken and two retired. . .
”Without deviation from the norm, progress is not possible.”
– Frank Zappa
RUNnDUC is offline   Reply With Quote
Boring and Nikasil nine16 Superbikes 11 Jan 28th, 2010 5:58 pm
