Stripped oil drain plug ?? - Ducati.ms - The Ultimate Ducati Forum
Honda PowersportsCycle GearMotorcycle.com Classifieds!
Go Back   Ducati.ms - The Ultimate Ducati Forum > Site Sponsors > Supporting Vendor Archives > Nirvana Motorsports
Old Mar 29th, 2009, 11:41 am   #1 (permalink)
Official Sponsor
nirvana996's Avatar
Images: 6
This is just an FYI for you fellow Ducati owners.
Some of you may be familiar with my safety wire oil drain plugs for both non deep sump and deep sump Ducatis.
I originally put together the billet magnetic drain plug because I wanted an easy to remove (hex) drain plug that could be easily safety wired for the track. I also wanted to still incorporate a magnet, and therefore designed a magnet to be installed on the "outside" of the plug so that there would be no possible way of it getting loose in the engine.
Most of you have bought the drain plug for the same reasons which is track use.
Increasingly, I am getting a number of Ducati owners who are buying the Nirvana Motorsports mag drain plug because they do not want to risk stripping the oil pan threads using the OEM plug. The reason being is that our billet drain plug is made of a softer 6061 aluminum which will not be able to strip the oil pan (the softer drain plug will strip first). They also do not want to strip the outside allen/hex which will make the plug impossible to get out (with out a chisel).
Once again , thanks to all the ducati.ms members out there.
Check out our Ducati performance parts at www.nirvanamotorsports.com .
Also check out store at:
Nirvana Motorsports
If you have any questions please PM me or send me an email.
Thanks
Andy
Nirvana Motorsports
andyb@nirvanamotorsports.com
nirvana996 is offline
Old Apr 15th, 2009, 10:23 am   #2 (permalink)
Lightbulb
If the drain plug is actually stripped you can still repair it with a steel insert.
TIME-SERT thread repair system for stripped drain plugs.
http://www.timesert.com/html/drainplug.html
Ric
RickCorona128 is offline
Oil Filling up in Spark Plug Bore - Rear Cylinder yellow blur Superbikes 8 Nov 27th, 2009 10:00 am
Stripped Oil Drain Plug ITALN Monster 6 Jan 10th, 2009 11:34 pm
Help!! Stripped the head of the 10mm oil plug drain deanp Sport Touring 13 Aug 8th, 2008 12:12 pm
Search Engine Friendly URLs by vBSEO 3.3.2
Kawasaki Forum Ducati Forum Harley Davidson Yamaha R1 BMW S1000RR Forum
Vulcan Forums Ducati Monster V-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley Forum YZF-R6 Forum Sportbike Forum
Kawasaki ZX-10R Honda 1000RR Suzuki SV Yamaha FZ8 Can Am Spyder
Kawasaki KLR 650 Honda RC51 Suzuki V-Strom Star Motorcycles Aprilia Forum
Kawasaki Versys Honda Fury Suzuki GSXR Triumph Forum KTM Forum
Kawasaki EX-500 Honda Goldwing GSX-R Forum Triumph 675 Victory Forums
